FineLine Precision Rolled 7832805
Nut Only, Screw Sold Separately;Integral wiper included as standard;Available in three preload classes (Type Z1, Z2, Z3) Z1 – light preload to 1-2% Z2 – no preload, clearance held to max indicated in table (standard unless specified) Z3 – no preload, clearance held to max .05mm;Part number 7832805 is sold in North America. This same product is sold in Europe under part number 0215200277 Ball Nut Only, FK Style, 40 mm X 5 mm, Non-Preloaded, RH, Flange, 0.09 Max Backlash, 26.3 kN Dynamic Load
Part Number 7832805_3ea00_40680154
Backlash, Max 0.09 mm
Company Thomson Linear
[D1] 63 mm
[D4] 78 mm
[D5] 9 mm
[D8] 93 mm
Flange Included
[G] M8x1
[L] 66 mm
[L1] 10 mm
[L10] 7 mm
[L2] 66 mm
[L3] 7 mm
[L6] 7 mm
[L7] 14 mm
[L8] 70 mm
[L9] 10 mm
Load Lock No
Maximum Static Load 59.2 kN
Preload Non-Preloaded
Return Style Button
Rolled/Ground/Whirled No
Root Dia No
Wiper No
Ball Bearing Diameter 3.5 mm
Ball Bearing Quantity No
Diameter Major No
Dynamic Load 26.3 kN
Length No
Screw Diameter,Nominal 40 mm
Standard Lead Accuracy ± No
Thread Direction RH
Travel Per Shaft Rev 5 mm
