FineLine Precision Rolled 7832798-P5
Screw only, No Ball nut;Our standard catalog ball screws feature a high luster polished and oiled finish, which provides, smoother operation, and a high quality look and feel.;Additional ball screw coatings (thin dense chrome, black oxide, manganese phosphate) are available as a custom item.;Part number 7832798-P5 is sold in North America. This same product is sold in Europe under part number 0205000302-RL6000;Please submit a drawing or description for a quotation on a machined screw or screw and nut assembly. Ball Screw Only, Rolled Thread, KGS Style, 32 mm X 10 mm, RH, 23 μm/300mm Lead Accuracy, Steel, 6000 mm Long
Part Number 7832798_p5_2b189_82783040
Backlash, Max No
Company Thomson Linear
[D1] No
[D4] No
[D5] No
[D8] No
Flange No
[G] No
[L] No
[L1] No
[L10] No
[L2] No
[L3] No
[L6] No
[L7] No
[L8] No
[L9] No
Load Lock No
Maximum Static Load No
Preload No
Return Style No
Rolled/Ground/Whirled Rolled Thread
Root Dia 27.1 mm
Wiper No
Ball Bearing Diameter No
Ball Bearing Quantity No
Diameter Major 31.6 mm
Dynamic Load No
Length 6000 mm
Screw Diameter,Nominal 32 mm
Standard Lead Accuracy ± 23 μm/300mm
Thread Direction RH
Travel Per Shaft Rev 10 mm
