FineLine Precision Rolled 7832791
Nut Only, Screw Sold Separately;Integral wiper included as standard;Available in three preload classes (Type Z1, Z2, Z3) Z1 – light preload to 1-2% Z2 – no preload, clearance held to max indicated in table (standard unless specified) Z3 – no preload, clearance held to max .05mm;Part number 7832791 is sold in North America. This same product is sold in Europe under part number 0215200243 Ball Nut Only, FH Style, 25 mm X 10 mm, RH, Flange, Wiper, 0.09 Max Backlash, 24.7 kN Dynamic Load
Part Number 7832791_17906_38092970
Backlash, Max 0.09 mm
Company Thomson Linear
[D1] 40 mm
[D4] 51 mm
[D5] 6.6 mm
[D8] 62 mm
Flange Included
[G] M6x1
[L] 51 mm
[L1] 20.7 mm
[L10] 5 mm
[L2] 51 mm
[L3] 10.15 mm
[L6] 10.15 mm
[L7] 10 mm
[L8] 48 mm
[L9] 8 mm
Load Lock Included
Maximum Static Load 53.4 kN
Preload Optional
Return Style Deflector
Rolled/Ground/Whirled No
Root Dia No
Wiper Included
Ball Bearing Diameter 3.5 mm
Ball Bearing Quantity 164
Diameter Major No
Dynamic Load 24.7 kN
Length No
Screw Diameter,Nominal 25 mm
Standard Lead Accuracy ± No
Thread Direction RH
Travel Per Shaft Rev 10 mm
