FineLine Precision Rolled 7832784
Nut Only, Screw Sold Separately;Integral wiper included as standard;Available in three preload classes (Type Z1, Z2, Z3) Z1 – light preload to 1-2% Z2 – no preload, clearance held to max indicated in table (standard unless specified) Z3 – no preload, clearance held to max .05mm;Part number 7832784 is sold in North America. This same product is sold in Europe under part number 0215200228 Ball Nut Only, FH Style, 20 mm X 20 mm, RH, Flange, Wiper, 0.08 Max Backlash, 10.8 kN Dynamic Load
Part Number 7832784_fc388_98455303
Backlash, Max 0.08 mm
Company Thomson Linear
[D1] 36 mm
[D4] 47 mm
[D5] 6.6 mm
[D8] 58 mm
Flange Included
[G] M6x1
[L] 36 mm
[L1] 4 mm
[L10] 5 mm
[L2] 36 mm
[L3] 11 mm
[L6] 11 mm
[L7] 10 mm
[L8] 44 mm
[L9] 8 mm
Load Lock Included
Maximum Static Load 17.5 kN
Preload Optional
Return Style Deflector
Rolled/Ground/Whirled No
Root Dia No
Wiper Included
Ball Bearing Diameter 3.5 mm
Ball Bearing Quantity 100
Diameter Major No
Dynamic Load 10.8 kN
Length No
Screw Diameter,Nominal 20 mm
Standard Lead Accuracy ± No
Thread Direction RH
Travel Per Shaft Rev 20 mm
