FineLine Precision Rolled 7832776-P5
Screw only, No Ball nut;Our standard catalog ball screws feature a high luster polished and oiled finish, which provides, smoother operation, and a high quality look and feel.;Additional ball screw coatings (thin dense chrome, black oxide, manganese phosphate) are available as a custom item.;Part number 7832776-P5 is sold in North America. This same product is sold in Europe under part number 0205000315-RL6000;Please submit a drawing or description for a quotation on a machined screw or screw and nut assembly. Ball Screw Only, Rolled Thread, KGS Style, 16 mm X 5 mm, RH, 23 μm/300mm Lead Accuracy, Steel, 3000 mm Long
Part Number 7832776_p5_e0e00_60238180
Backlash, Max No
Company Thomson Linear
[D1] No
[D4] No
[D5] No
[D8] No
Flange No
[G] No
[L] No
[L1] No
[L10] No
[L2] No
[L3] No
[L6] No
[L7] No
[L8] No
[L9] No
Load Lock No
Maximum Static Load No
Preload No
Return Style No
Rolled/Ground/Whirled Rolled Thread
Root Dia 12.7 mm
Wiper No
Ball Bearing Diameter No
Ball Bearing Quantity No
Diameter Major 15.6 mm
Dynamic Load No
Length 3000 mm
Screw Diameter,Nominal 16 mm
Standard Lead Accuracy ± 23 μm/300mm
Thread Direction RH
Travel Per Shaft Rev 5 mm
