FineLine Precision Rolled 7832770-P5
Screw only, No Ball nut;Our standard catalog ball screws feature a high luster polished and oiled finish, which provides, smoother operation, and a high quality look and feel.;Additional ball screw coatings (thin dense chrome, black oxide, manganese phosphate) are available as a custom item.;Part number 7832770-P5 is sold in North America. This same product is sold in Europe under part number 0205000318-RL3000;Please submit a drawing or description for a quotation on a machined screw or screw and nut assembly. Ball Screw Only, Rolled Thread, KGS Style, 12 mm X 4 mm, RH, 23 μm/300mm Lead Accuracy, Steel, 3000 mm Long
Part Number 7832770_p5_dcf85_55182628
Backlash, Max No
Company Thomson Linear
[D1] No
[D4] No
[D5] No
[D8] No
Flange No
[G] No
[L] No
[L1] No
[L10] No
[L2] No
[L3] No
[L6] No
[L7] No
[L8] No
[L9] No
Load Lock No
Maximum Static Load No
Preload No
Return Style No
Rolled/Ground/Whirled Rolled Thread
Root Dia 9.7 mm
Wiper No
Ball Bearing Diameter No
Ball Bearing Quantity No
Diameter Major 11.6 mm
Dynamic Load No
Length 3000 mm
Screw Diameter,Nominal 12 mm
Standard Lead Accuracy ± 23 μm/300mm
Thread Direction RH
Travel Per Shaft Rev 4 mm
