FineLine Precision Rolled 0215900264
Nut Only, Screw Sold Separately;Integral wiper included as standard;Available in three preload classes (Type Z1, Z2, Z3) Z1 – light preload to 1-2% Z2 – no preload, clearance held to max indicated in table (standard unless specified) Z3 – no preload, clearance held to max .05mm;Part number 0215900264 is sold in Europe. This same product is sold in North America under part number 7832803 KGF-D-3220-RH-D-KK (FH-3220), Ball Nut Only, FH Style, 32 mm X 20 mm, RH, Flange, Wiper, 0.065 Max Backlash, 47.2 kN Dynamic Load
Part Number 0215900264_23480_59656798
Backlash, Max 0.065 mm
Company Thomson Linear
[D1] 56 mm
[D4] 71 mm
[D5] 9 mm
[D8] 86 mm
Flange Included
[G] M6x1
[L] 83 mm
[L1] 25 mm
[L10] 6 mm
[L2] 83 mm
[L3] 15 mm
[L6] 15 mm
[L7] 12 mm
[L8] 65 mm
[L9] 9 mm
Load Lock Included
Maximum Static Load 83.2 kN
Preload Optional
Return Style Deflector
Rolled/Ground/Whirled No
Root Dia No
Wiper Included
Ball Bearing Diameter 5.556 mm
Ball Bearing Quantity 136
Diameter Major No
Dynamic Load 47.2 kN
Length No
Screw Diameter,Nominal 32 mm
Standard Lead Accuracy ± No
Thread Direction RH
Travel Per Shaft Rev 20 mm
