FineLine Precision Rolled 0215900239
Nut Only, Screw Sold Separately;Integral wiper included as standard;Available in three preload classes (Type Z1, Z2, Z3) Z1 – light preload to 1-2% Z2 – no preload, clearance held to max indicated in table (standard unless specified) Z3 – no preload, clearance held to max .05mm;Part number 0215900239 is sold in Europe. This same product is sold in North America under part number 7832794 KGF-D-2525-RH-D-KK (FH-2525), Ball Nut Only, FH Style, 25 mm X 25 mm, RH, Flange, Wiper, 0.041 Max Backlash, 13.1 kN Dynamic Load
Part Number 0215900239_07f09_17350038
Backlash, Max 0.041 mm
Company Thomson Linear
[D1] 40 mm
[D4] 51 mm
[D5] 6.6 mm
[D8] 62 mm
Flange Included
[G] M6x1
[L] 39 mm
[L1] 9 mm
[L10] 5 mm
[L2] 39 mm
[L3] 10 mm
[L6] 10 mm
[L7] 10 mm
[L8] 48 mm
[L9] 8 mm
Load Lock Included
Maximum Static Load 26 kN
Preload Optional
Return Style Deflector
Rolled/Ground/Whirled No
Root Dia No
Wiper Included
Ball Bearing Diameter 3.5 mm
Ball Bearing Quantity 120
Diameter Major No
Dynamic Load 13.1 kN
Length No
Screw Diameter,Nominal 25 mm
Standard Lead Accuracy ± No
Thread Direction RH
Travel Per Shaft Rev 25 mm
