FineLine Precision Rolled 0215200346
Nut Only, Screw Sold Separately;Integral wiper included as standard;Available in three preload classes (Type Z1, Z2, Z3) Z1 – light preload to 1-2% Z2 – no preload, clearance held to max indicated in table (standard unless specified) Z3 – no preload, clearance held to max .05mm , Ball Nut Only, FK Style, 32 mm X 10 mm, RH, Flange, 0.065 Max Backlash, 26.4 kN Dynamic Load
Part Number 0215200346_d9102_85433102
Backlash, Max 0.065 mm
Company Thomson Linear
[D1] 50 mm
[D4] 65 mm
[D5] 9 mm
[D8] 80 mm
Flange Included
[G] No
[L] 73 mm
[L1] 16 mm
[L10] No
[L2] No
[L3] 6 mm
[L6] No
[L7] 12 mm
[L8] 62 mm
[L9] No
Load Lock No
Maximum Static Load 39 kN
Preload Optional
Return Style Button
Rolled/Ground/Whirled No
Root Dia No
Wiper No
Ball Bearing Diameter 5.556 mm
Ball Bearing Quantity No
Diameter Major No
Dynamic Load 26.4 kN
Length No
Screw Diameter,Nominal 32 mm
Standard Lead Accuracy ± No
Thread Direction RH
Travel Per Shaft Rev 10 mm
