FineLine Precision Rolled 0215200277
Nut Only, Screw Sold Separately;Integral wiper included as standard;Available in three preload classes (Type Z1, Z2, Z3) Z1 – light preload to 1-2% Z2 – no preload, clearance held to max indicated in table (standard unless specified) Z3 – no preload, clearance held to max .05mm;Part number 0215200277 is sold in Europe. This same product is sold in North America under part number 7832805 KGF-D-4005-RH-E-KK (FK-4005), Ball Nut Only, FK Style, 40 mm X 5 mm, RH, Flange, 0.041 Max Backlash, 26.3 kN Dynamic Load
Part Number 0215200277_36d02_15772162
Backlash, Max 0.041 mm
Company Thomson Linear
[D1] 63 mm
[D4] 78 mm
[D5] 9 mm
[D8] 93 mm
Flange Included
[G] M8x1
[L] 66 mm
[L1] 10 mm
[L10] 7 mm
[L2] 66 mm
[L3] 7 mm
[L6] 7 mm
[L7] 14 mm
[L8] 70 mm
[L9] 10 mm
Load Lock No
Maximum Static Load 59.2 kN
Preload Optional
Return Style Button
Rolled/Ground/Whirled No
Root Dia No
Wiper No
Ball Bearing Diameter 3.5 mm
Ball Bearing Quantity No
Diameter Major No
Dynamic Load 26.3 kN
Length No
Screw Diameter,Nominal 40 mm
Standard Lead Accuracy ± No
Thread Direction RH
Travel Per Shaft Rev 5 mm
