FineLine Precision Rolled 0215200269
Nut Only, Screw Sold Separately;Integral wiper included as standard;Available in three preload classes (Type Z1, Z2, Z3) Z1 – light preload to 1-2% Z2 – no preload, clearance held to max indicated in table (standard unless specified) Z3 – no preload, clearance held to max .05mm;Part number 0215200269 is sold in Europe. This same product is sold in North America under part number 7832777 KGF-D-1605-RH-E-KK (FK-1605-MIM), Ball Nut Only, FK Style, 16 mm X 5 mm, RH, Flange, 0.041 Max Backlash, 9.5 kN Dynamic Load
Part Number 0215200269_e0e07_57860550
Backlash, Max 0.041 mm
Company Thomson Linear
[D1] 28 mm
[D4] 38 mm
[D5] 5.5 mm
[D8] 48 mm
Flange Included
[G] M6x1
[L] 48.5 mm
[L1] 10 mm
[L10] 5 mm
[L2] 48.5 mm
[L3] 5.5 mm
[L6] 5.5 mm
[L7] 10 mm
[L8] 40 mm
[L9] 8 mm
Load Lock No
Maximum Static Load 10.9 kN
Preload Optional
Return Style Button
Rolled/Ground/Whirled No
Root Dia No
Wiper No
Ball Bearing Diameter 3.5 mm
Ball Bearing Quantity No
Diameter Major No
Dynamic Load 9.5 kN
Length No
Screw Diameter,Nominal 16 mm
Standard Lead Accuracy ± No
Thread Direction RH
Travel Per Shaft Rev 5 mm
