FineLine Precision Rolled 0215200243
Nut Only, Screw Sold Separately;Integral wiper included as standard;Available in three preload classes (Type Z1, Z2, Z3) Z1 – light preload to 1-2% Z2 – no preload, clearance held to max indicated in table (standard unless specified) Z3 – no preload, clearance held to max .05mm;Part number 0215200243 is sold in Europe. This same product is sold in North America under part number 7832791 KGF-D-2510-RH-D-KK (FH-2510), Ball Nut Only, FH Style, 25 mm X 10 mm, RH, Flange, Wiper, 0.041 Max Backlash, 24.7 kN Dynamic Load
Part Number 0215200243_00201_35680971
Backlash, Max 0.041 mm
Company Thomson Linear
[D1] 40 mm
[D4] 51 mm
[D5] 6.6 mm
[D8] 62 mm
Flange Included
[G] M6x1
[L] 51 mm
[L1] 20.7 mm
[L10] 5 mm
[L2] 51 mm
[L3] 10.15 mm
[L6] 10.15 mm
[L7] 10 mm
[L8] 48 mm
[L9] 8 mm
Load Lock Included
Maximum Static Load 53.4 kN
Preload Optional
Return Style Deflector
Rolled/Ground/Whirled No
Root Dia No
Wiper Included
Ball Bearing Diameter 3.5 mm
Ball Bearing Quantity 164
Diameter Major No
Dynamic Load 24.7 kN
Length No
Screw Diameter,Nominal 25 mm
Standard Lead Accuracy ± No
Thread Direction RH
Travel Per Shaft Rev 10 mm
