FineLine Precision Rolled 0215200232
Nut Only, Screw Sold Separately;Integral wiper included as standard;Available in three preload classes (Type Z1, Z2, Z3) Z1 – light preload to 1-2% Z2 – no preload, clearance held to max indicated in table (standard unless specified) Z3 – no preload, clearance held to max .05mm;Part number 0215200232 is sold in Europe. This same product is sold in North America under part number 7833300 KGF-D-3232-RH-D-KK (FH-3232), Ball Nut Only, FH Style, 32 mm X 32 mm, RH, Flange, Wiper, 0.047 Max Backlash, 19.7 kN Dynamic Load
Part Number 0215200232_1b789_93899709
Backlash, Max 0.047 mm
Company Thomson Linear
[D1] 56 mm
[D4] 71 mm
[D5] 9 mm
[D8] 86 mm
Flange Included
[G] M6x1
[L] 42 mm
[L1] 12 mm
[L10] 6 mm
[L2] 42 mm
[L3] 9 mm
[L6] 9 mm
[L7] 12 mm
[L8] 68 mm
[L9] 8 mm
Load Lock Included
Maximum Static Load 39 kN
Preload Optional
Return Style Deflector
Rolled/Ground/Whirled No
Root Dia No
Wiper Included
Ball Bearing Diameter 3.969 mm
Ball Bearing Quantity 124
Diameter Major No
Dynamic Load 19.7 kN
Length No
Screw Diameter,Nominal 32 mm
Standard Lead Accuracy ± No
Thread Direction RH
Travel Per Shaft Rev 32 mm
