FineLine Precision Rolled 0215200228
Nut Only, Screw Sold Separately;Integral wiper included as standard;Available in three preload classes (Type Z1, Z2, Z3) Z1 – light preload to 1-2% Z2 – no preload, clearance held to max indicated in table (standard unless specified) Z3 – no preload, clearance held to max .05mm;Part number 0215200228 is sold in Europe. This same product is sold in North America under part number 7832784 KGF-D-2020-RH-D-KK (FH-2020), Ball Nut Only, FH Style, 20 mm X 20 mm, RH, Flange, Wiper, 0.041 Max Backlash, 10.8 kN Dynamic Load
Part Number 0215200228_f0805_05908137
Backlash, Max 0.041 mm
Company Thomson Linear
[D1] 36 mm
[D4] 47 mm
[D5] 6.6 mm
[D8] 58 mm
Flange Included
[G] M6x1
[L] 36 mm
[L1] 4 mm
[L10] 5 mm
[L2] 36 mm
[L3] 11 mm
[L6] 11 mm
[L7] 10 mm
[L8] 44 mm
[L9] 8 mm
Load Lock Included
Maximum Static Load 17.5 kN
Preload Optional
Return Style Deflector
Rolled/Ground/Whirled No
Root Dia No
Wiper Included
Ball Bearing Diameter 3.5 mm
Ball Bearing Quantity 100
Diameter Major No
Dynamic Load 10.8 kN
Length No
Screw Diameter,Nominal 20 mm
Standard Lead Accuracy ± No
Thread Direction RH
Travel Per Shaft Rev 20 mm
