FDM0620-RV-V6-15+06/1 16:1+MG32
FAULHABER® PRECIstep® Technology series FDM0620, 6 mm dia. 2 phase disc magnet DC stepper motor, 6.0V coil with Dicronite (Dry Lubricant). with FAULHABER® series 06/1, 6 mm dia. precision planetary gearhead, 16:1 reduction ratio and 1.0 mm dia. output shaft.
Part Number fdm0620_rv_v6_15_06_1_16_1_mg3
Back EMF Constant Rotary 1.6 mV/rpm
Company MicroMo
Continuous Torque, Max. 25 mNm
Direction Of Rotation CW
Dynamic Friction 00 mNm/rpm
Efficiency [%] No
Friction Torque/Residual Torque 0.1 mNm
Gearhead Intermittent Input Speed, Max. 24000 rpm
Gearhead Ratio 16:1
Gearhead Series 06/1
Intermittent Torque, Max. 35 mNm
Lead Time 20 Business Days
Motor Series FDM0620
Motor Winding Description 6V
Operating Temp, Max. 100 °C
Operating Temp, Min. -30 °C
Overall Diameter 6 mm
Overall Length 21.4 mm
Overall Weight 09 lbs
Radial Shaft Load, Max. 0.5 N
Recommended Input Speed, Max. 8000 rpm
Rotor Inertia 0.0 gcm2
Stepper Drive Voltage, Min. 15 V
Terminal Inductance 18.5 μH
Terminal/Phase Resistance 120 Ω
Torque Constant Rotary 0.06 mNm/A
