FDM0620-2R-V6-10
FDM0620-2R-V6-10
FAULHABER® PRECIstep® Technology series FDM0620, 6 mm dia. 2 phase disc magnet DC stepper motor, 6.0V coil with two ball bearings. and 0.8 mm dia. plain shaft.
Part Number fdm0620_2r_v6_10
Back EMF Constant Rotary 1.6 mV/rpm
Company MicroMo
Continuous Torque, Max. No
Direction Of Rotation No
Dynamic Friction 00 mNm/rpm
Efficiency [%] No
Friction Torque/Residual Torque 0.1 mNm
Gearhead Intermittent Input Speed, Max. No
Gearhead Ratio No
Gearhead Series No
Intermittent Torque, Max. No
Lead Time 20 Business Days
Motor Series FDM0620
Motor Winding Description 6V
Operating Temp, Max. No
Operating Temp, Min. No
Overall Diameter 6 mm
Overall Length 9.5 mm
Overall Weight 02 lbs
Radial Shaft Load, Max. No
Recommended Input Speed, Max. No
Rotor Inertia 0.0 gcm2
Stepper Drive Voltage, Min. 15 V
Terminal Inductance 18.5 μH
Terminal/Phase Resistance 120 Ω
Torque Constant Rotary 0.06 mNm/A
