E5 Optical Kit Encoder
The E5 Series rotary encoder has a molded polycarbonate enclosure with either a 5-pin or 10-pin latching connector. This optical incremental encoder is designed to easily mount to and dismount from an existing motor shaft to provide digital feedback information.       The E5 Series is easy to add to existing applications and only consists of five main components: base, cover, hubdisk, optical encoder module and internal differential line driver (differential version only).  The single-ended output version (S-option) is typically used with cables of 10 feet or less. For longer cable lengths, the differential output version (D-option) is recommended.The base and cover are both constructed of a rugged 20% glass filled polycarbonate. Attachment of the base to a surface may be accomplished by utilizing one of several machine screw bolt circle options. Positioning of the base to the centerline of a shaft is ensured by use of a centering tool (sold separately). The cover is securely attached to the base with two 4-40 flat head screws to provide a resilient package protecting the internal components.The internal components consist of a mylar disk mounted to a precision machined aluminum hub and an encoder module. The module consists of a highly collimated solid state light source and monolithic phased array sensor, which together provide a system extremely tolerant to mechanical misalignments.A secure connection to the E5 Series encoder is made through a 5-pin (single-ended versions) or 10-pin (differential versions) latching connector (sold separately). The mating connectors are available from US Digital with several cable options and lengths.Avago Replacements:US Digital's E5 encoder may now be used as a replacement for Avago HEDL-5500, HEDL-5600.  Quick, simple assembly and disassembly Rugged screw-together housing Positive latching connector Accepts .010" axial shaft play 32 to 5,000 cycles per revolution (CPR) 128 to 20,000 pulses per revolution (PPR) 2 channel quadrature TTL squarewave outputs Optional index (3rd channel) Mounting compatibility with HEDS-5500
Part Number e5_optical_kit_encoder
Company US Digital
Operating Temperature (CPR < 2000), C -40 to 100
Operating Temperature (CPR ≥ 2000), C -40 to 100
Operating Temperature (CPR < 3600), C -40 to 100
Operating Temperature (CPR ≥ 3600), C -40 to 100
Supply Voltage, V 4.5 to 5.5
Vibration (5Hz to 2kHz), G 20
Weight Oz Single-ended 0.82, Differential 0.91
Max. Acceleration, rad/sec2 250000
