Compact Dynamic Brushless Servo Motor
Moog Compact Dynamic Brushless Servo Motors are designed for highly dynamic servo applications where positioning times of 30 mSec or less are often the norm. The Moog Compact Dynamic Brushless Servo Motor offers one of the industry’s widest power ranges with standard models available at continuous stall torque ratings from 0.15 to 77 Nm (1.3 to 681 lb-in). The modular design is supported by a variety of options with Moog application engineers capable of supplying fully customized solutions.
AC Servo Motor (Synchronous)
Low inertia, compact length
Type of Motor: Totally enclosed, natural cooling (optional fan ventilation)
High voltage (600 Vdc Brushless Servo Motor) available
Flameproof servo motors available
Superior dynamics improves cycle timeCompact, lightweightProprietary low-cogging designRugged, minimum maintenanceFlexible design
Part Number Compact_Dynamic_Brushless_Servo_Motor
Continuous stall torque M°, Nm [lb-in] 0.15-77 [1.3-681]
Peak torque M-max, Nm [lb-in] 0.5-240 [4.4-2124]
Rated Speed nN, min-1 [rpm] 9000-2200
Rated Power Pn, kW [hp] 0.13-12 [0.2-16]
Rated Torque Mn, Nm [lb-in] 0.14-48 [1.2-425]
Moment of Inertia J, Kg cm2 [lb-insec2 x 10-4] 0.09-152 [0.8-1345]
Position transducer, Standard / Optional Resolver / Encoder
Temperature monitoring NTC or PTC
Brake Optional
Rated bus voltage Vdc, V 325/565
Certificate/marks CE, UL/cUL
Cooling Natural
Company Moog
