BSM90N-375BA
BSM90N-375BA
BSM90N-375BA TSTAT, BRAKE,
Company Baldor
Part Number bsm90n_375ba
AMB. 25
Ambient Temperature 25 C
Base Indicator Bracket Mounted
Bearing Grease Type POLYREX EM
CLASS F
Constant stall current 19.01 A
CUR CONT STALL/A RMS 19
Dimensional Drawing Numbers S3LYP101
Duty Rating CONT
Frame D130D
Frame Material Exposed Laminations
Frame Suffix D
Insulation Class F
IP Rating No
MAX MECH SPEED No
Max Speed 7,000 rpm
Max Speed Rpm 7000
Motor Lead Exit Front End
Motor Lead Quantity/Wire Size 3 @ 14 AWG
Multiplier Symbol E4
Nameplate Amps 19
Nameplate Output 3.46KW
Nameplate Speed 4000
Nameplate Voltage 300
Number of Poles 8
PEACK CUR/A RMS 68,5
Peak Current 68.5 A
Peak Torque 53.2 N-m
POWER 3.46KW
RATED BUS VOLTS 300
RATED SPEED/RPM 4000
Rated Torque 13.30 N-m
RoHS Status RoHS Compliant
Rotor Inertia (Servo) 0,0084
Shaft Diameter 0.945 in
Ship Weight 43 LB
SPEC. S3P101W063G1
Speed 4,000 rpm
Thermal Resistance No
Thermal Time Constant No
TORQ CONT STALL 13.3 NM
UPC 781568441480
