BSM90N-275AF
BSM90N-275AF
BSM90N-275AF TSTAT ENCODER
Company Baldor
Part Number bsm90n_275af
AMB. 25
Ambient Temperature 25 C
Base Indicator Bracket Mounted
Bearing Grease Type POLYREX EM
CLASS F
Constant stall current 11.60 A
CUR CONT STALL/A RMS 11,6
Dimensional Drawing Numbers S3LYP136
Duty Rating CONT
Frame D130D
Frame Material Exposed Laminations
Frame Suffix D
Insulation Class F
IP Rating No
MAX MECH SPEED No
Max Speed 7,000 rpm
Max Speed Rpm 7000
Motor Lead Exit Front End
Motor Lead Quantity/Wire Size 3 @ 16 AWG
Multiplier Symbol E4
Nameplate Amps 11,6
Nameplate Output 2.59KW
Nameplate Speed 4000
Nameplate Voltage 300
Number of Poles 8
PEACK CUR/A RMS 41,9
Peak Current 41.9 A
Peak Torque 40.0 N-m
POWER 2.59KW
RATED BUS VOLTS 300
RATED SPEED/RPM 4000
Rated Torque 10 N-m
RoHS Status RoHS Compliant
Rotor Inertia (Servo) 0,0056
Shaft Diameter 0.945 in
Ship Weight 31.4 LB
SPEC. S3P136W060
Speed 4,000 rpm
Thermal Resistance No
Thermal Time Constant No
TORQ CONT STALL 10 NM
UPC 781568535523
