BSM90N-2250AA
BSM90N-2250AA
BSM90N-2250AA (NEO) TSTAT, RESOLVE
Company Baldor
Part Number bsm90n_2250aa
AMB. 25
Ambient Temperature 25 C
Base Indicator Bracket Mounted
Bearing Grease Type POLYREX EM
CLASS F
Constant stall current 4.19 A
CUR CONT STALL/A RMS 4,19
Dimensional Drawing Numbers S3LYP100
Duty Rating CONT
Frame D130D
Frame Material Exposed Laminations
Frame Suffix D
Insulation Class F
IP Rating No
MAX MECH SPEED No
Max Speed 7,000 rpm
Max Speed Rpm 7000
Motor Lead Exit Front End
Motor Lead Quantity/Wire Size 3 @ 16 AWG
Multiplier Symbol E4
Nameplate Amps 4,19
Nameplate Output 0.52KW
Nameplate Speed 1200
Nameplate Voltage 300
Number of Poles 8
PEACK CUR/A RMS 15,1
Peak Current 15.1 A
Peak Torque 40.0 N-m
POWER 0.52KW
RATED BUS VOLTS 300
RATED SPEED/RPM 1200
Rated Torque 10 N-m
RoHS Status RoHS Compliant
Rotor Inertia (Servo) 0,0056
Shaft Diameter 0.945 in
Ship Weight 26.9 LB
SPEC. S3P100W062G1
Speed 1,200 rpm
Thermal Resistance No
Thermal Time Constant No
TORQ CONT STALL 10 NM
UPC 781568293614
