BSM90N-1150AA
BSM90N-1150AA
BSM90N-1150AA (NEO) TSTAT, RESOLVE
Company Baldor
Part Number bsm90n_1150aa
AMB. 25
Ambient Temperature 25 C
Base Indicator Bracket Mounted
Bearing Grease Type POLYREX EM
CLASS F
Constant stall current 4.03 A
CUR CONT STALL/A RMS 4,03
Dimensional Drawing Numbers S3LYP100
Duty Rating CONT
Frame D130D
Frame Material Exposed Laminations
Frame Suffix D
Insulation Class F
IP Rating No
MAX MECH SPEED No
Max Speed 7,000 rpm
Max Speed Rpm 7000
Motor Lead Exit Front End
Motor Lead Quantity/Wire Size 3 @ 16 AWG
Multiplier Symbol E4
Nameplate Amps 4,03
Nameplate Output 1KW
Nameplate Speed 2000
Nameplate Voltage 300
Number of Poles 8
PEACK CUR/A RMS 14,5
Peak Current 14.5 A
Peak Torque 24.0 N-m
POWER 1KW
RATED BUS VOLTS 300
RATED SPEED/RPM 2000
Rated Torque 6 N-m
RoHS Status RoHS Compliant
Rotor Inertia (Servo) 0,003
Shaft Diameter 0.945 in
Ship Weight 25 LB
SPEC. S3P100W058G1
Speed 2,000 rpm
Thermal Resistance No
Thermal Time Constant No
TORQ CONT STALL 6 NM
UPC 781568293577
