BSM90C-3150AF
BSM90C-3150AF
BSM90C-3150AF TSTAT, ENCODER
Company Baldor
Part Number bsm90c_3150af
Agency Approvals CE CSA TUV UR
AMB. 25
Ambient Temperature 25 C
AMPS No
Base Indicator Bracket Mounted
Bearing Grease Type POLYREX EM
BRG/DE No
BRG/ODE No
CLASS F
Constant stall current 6 A
CUR CONT STALL/A RMS 6,04
Dimensional Drawing Numbers S3LYP193
DUTY No
Duty Rating CONT
ENCL No
Frame No
Frame Material Exposed Laminations
Frame Suffix D
HP No
INSUL No
Insulation Class F
IP Rating No
Max Speed 7,000 rpm
Max Speed Rpm 7000
Motor Lead Exit Front End
Motor Lead Quantity/Wire Size 3 @ 16 AWG
Multiplier Symbol E4
Nameplate Amps 6,04
Nameplate Output 1.66KW
Nameplate Speed 4000
Nameplate Voltage 600
Number of Poles 8
PEACK CUR/A RMS 15,4
Peak Current 15.4 A
Peak Torque 23.4 N-m
POWER 1.66KW
RATED BUS VOLTS 600
RATED SPEED/RPM 4000
Rated Torque 7.80 N-m
RoHS Status RoHS Compliant
Rotor Inertia (Servo) 0,01173
RPM No
SER.F. No
Service Factor No
Shaft Diameter 0.945 in
Ship Weight 33.6 LB
SPEC. S3P193W082G1
Speed 4,000 rpm
TORQ CONT STALL 7.8 NM
UPC 781568378373
VOLTS No
