BSM90C-2250AA
BSM90C-2250AA
BSM90C-2250AA TSTAT, RESOLVE
Company Baldor
Part Number bsm90c_2250aa
Agency Approvals CE CSA TUV UR
AMB. 25
Ambient Temperature 25 C
AMPS No
Base Indicator Bracket Mounted
Bearing Grease Type POLYREX EM
BRG/DE No
BRG/ODE No
CLASS F
Constant stall current 2.51 A
CUR CONT STALL/A RMS 2,51
Dimensional Drawing Numbers S3LYP155
DUTY No
Duty Rating CONT
ENCL No
Frame No
Frame Material Exposed Laminations
Frame Suffix D
HP No
INSUL No
Insulation Class F
IP Rating No
Max Speed 7,000 rpm
Max Speed Rpm 7000
Motor Lead Exit Front End
Motor Lead Quantity/Wire Size 3 @ 18 AWG
Multiplier Symbol E4
Nameplate Amps 2,51
Nameplate Output 0.67KW
Nameplate Speed 1200
Nameplate Voltage 300
Number of Poles 8
PEACK CUR/A RMS 6,39
Peak Current 6.4 A
Peak Torque 15.6 N-m
POWER 0.67KW
RATED BUS VOLTS 300
RATED SPEED/RPM 1200
Rated Torque 5.20 N-m
RoHS Status RoHS Compliant
Rotor Inertia (Servo) 0,00782
RPM No
SER.F. No
Service Factor No
Shaft Diameter 0.945 in
Ship Weight 26.8 LB
SPEC. S3P155W080
Speed 1,200 rpm
TORQ CONT STALL 5.2 NM
UPC 781568387238
VOLTS No
