BSM90C-1150AA
BSM90C-1150AA
BSM90C-1150AA TSTAT, RESOLVER
Company Baldor
Part Number bsm90c_1150aa
Agency Approvals CE CSA TUV UR
AMB. 25
Ambient Temperature 25 C
AMPS No
Base Indicator Bracket Mounted
Bearing Grease Type POLYREX EM
BRG/DE No
BRG/ODE No
CLASS F
Constant stall current 2.15 A
CUR CONT STALL/A RMS 2,15
Dimensional Drawing Numbers S3LYP155
DUTY No
Duty Rating CONT
ENCL No
Frame No
Frame Material Exposed Laminations
Frame Suffix D
HP No
INSUL No
Insulation Class F
IP Rating No
Max Speed 7,000 rpm
Max Speed Rpm 7000
Motor Lead Exit Front End
Motor Lead Quantity/Wire Size 3 @ 18 AWG
Multiplier Symbol E4
Nameplate Amps 2,15
Nameplate Output 0.55KW
Nameplate Speed 2000
Nameplate Voltage 300
Number of Poles 8
PEACK CUR/A RMS 5,47
Peak Current 5.5 A
Peak Torque 7.8 N-m
POWER 0.55KW
RATED BUS VOLTS 300
RATED SPEED/RPM 2000
Rated Torque 2.60 N-m
RoHS Status RoHS Compliant
Rotor Inertia (Servo) 0,00391
RPM No
SER.F. No
Service Factor No
Shaft Diameter 0.945 in
Ship Weight 20.285 LB
SPEC. S3P155W076
Speed 2,000 rpm
TORQ CONT STALL 2.6 NM
UPC 781568387221
VOLTS No
