BSM90B-3150AA
BSM90B-3150AA
BSM90B-3150AA T'STAT, RESOLVE
Company Baldor
Part Number bsm90b_3150aa
AMB. 25
Ambient Temperature 25 C
Base Indicator Bracket Mounted
Bearing Grease Type POLYREX EM
CLASS F
CUR CONT STALL/A RMS 5,31
Dimensional Drawing Numbers S3LYP100
Duty Rating CONT
Frame D130D
Frame Material Exposed Laminations
Frame Suffix D
Insulation Class F
IP Rating No
Max Speed 7,000 rpm
Max Speed Rpm 7000
Motor Lead Exit Front End
Motor Lead Quantity/Wire Size 3 @ 16 AWG
Multiplier Symbol E4
Nameplate Amps 5,31
Nameplate Output 1.21KW
Nameplate Speed 2000
Nameplate Voltage 300
Number of Poles 8
PEACK CUR/A RMS 13,5
Peak Current 13.5 A
Peak Torque 19.5 N-m
POWER 1.21KW
RATED BUS VOLTS 300
RATED SPEED/RPM 2000
Rated Torque 6.50 N-m
RoHS Status RoHS Compliant
Rotor Inertia (Servo) 0,0117
Shaft Diameter 0.945 in
Ship Weight 40 LB
SPEC. S3P100W004G1
Speed 2,000 rpm
TORQ CONT STALL 6.5 NM
UPC 781568186480
