BSM90B-2150AA
BSM90B-2150AA
BSM90B-2150AA T'STATS
Company Baldor
Part Number bsm90b_2150aa
AMB. 25
Ambient Temperature 25 C
Base Indicator Bracket Mounted
Bearing Grease Type POLYREX EM
CLASS F
CUR CONT STALL/A RMS 3,71
Dimensional Drawing Numbers S3LYP100
Duty Rating CONT
Frame D130D
Frame Material Exposed Laminations
Frame Suffix D
Insulation Class F
IP Rating No
Max Speed 7,000 rpm
Max Speed Rpm 7000
Motor Lead Exit Front End
Motor Lead Quantity/Wire Size 3 @ 18 AWG
Multiplier Symbol E4
Nameplate Amps 3,71
Nameplate Output 0.87KW
Nameplate Speed 2000
Nameplate Voltage 300
Number of Poles 8
PEACK CUR/A RMS 9,47
Peak Current 9.5 A
Peak Torque 12.9 N-m
POWER 0.87KW
RATED BUS VOLTS 300
RATED SPEED/RPM 2000
Rated Torque 4.30 N-m
RoHS Status RoHS Compliant
Rotor Inertia (Servo) 0,0079
Shaft Diameter 0.945 in
Ship Weight 33 LB
SPEC. S3P100W003G2
Speed 2,000 rpm
TORQ CONT STALL 4.3 NM
UPC 781568186497
