BSM80N-375RA
BSM80N-375RA
BSM80N-375RA TSTAT RESOLVER
Company Baldor
Part Number bsm80n_375ra
AMB. 25
Ambient Temperature 25 C
Base Indicator Bracket Mounted
Bearing Grease Type POLYREX EM
CLASS F
Constant stall current 5.54 A
CUR CONT STALL/A RMS 5,35
Dimensional Drawing Numbers S2LYP262
Duty Rating CONT
Frame D100D
Frame Material Exposed Laminations
Frame Suffix D
Insulation Class F
IP Rating No
MAX MECH SPEED No
Max Speed 7,000 rpm
Max Speed Rpm 7000
Motor Lead Exit Front End
Motor Lead Quantity/Wire Size 3 @ 18 AWG
Multiplier Symbol E4
Nameplate Amps 5,35
Nameplate Output 1.28KW
Nameplate Speed 4000
Nameplate Voltage 300
Number of Poles 4
PEACK CUR/A RMS 19,3
Peak Current 19.3 A
Peak Torque 18.1 N-m
POWER 1.28KW
RATED BUS VOLTS 300
RATED SPEED/RPM 4000
Rated Torque 4.52 N-m
RoHS Status RoHS Compliant
Rotor Inertia (Servo) 0,00223
Shaft Diameter 0.748 in
Ship Weight 15 LB
SPEC. S2P262W045
Speed 4,000 rpm
Thermal Resistance No
Thermal Time Constant No
TORQ CONT STALL 4.52 NM
UPC 781568500095
