BSM80N-233AA
BSM80N-233AA
BSM80N-233AA (NEO) TSTAT, RESOLVER
Company Baldor
Part Number bsm80n_233aa
AMB. 25
Ambient Temperature 25 C
Base Indicator Bracket Mounted
Bearing Grease Type POLYREX EM
CLASS F
Constant stall current 8.76 A
CUR CONT STALL/A RMS 8,82
Dimensional Drawing Numbers S2LYP100
Duty Rating CONT
Frame D100D
Frame Material Exposed Laminations
Frame Suffix D
Insulation Class F
IP Rating IP54
MAX MECH SPEED No
Max Speed 7,000 rpm
Max Speed Rpm 7000
Motor Lead Exit Front End
Motor Lead Quantity/Wire Size 3 @ 16 AWG
Multiplier Symbol E4
Nameplate Amps 8,82
Nameplate Output 1.57KW
Nameplate Speed 6000
Nameplate Voltage 200
Number of Poles 4
PEACK CUR/A RMS 31,8
Peak Current 31.8 A
Peak Torque 12.8 N-m
POWER 1.57KW
RATED BUS VOLTS 200
RATED SPEED/RPM 6000
Rated Torque 3.20 N-m
RoHS Status RoHS Compliant
Rotor Inertia (Servo) 0,00152
Shaft Diameter 0.748 in
Ship Weight 12 LB
SPEC. S2P100W044G1
Speed 6,000 rpm
Thermal Resistance No
Thermal Time Constant No
TORQ CONT STALL 3.2 NM
UPC 781568293492
