BSM80N-175BA
BSM80N-175BA
BSM80N-175BA TSTAT, RESOLVER,
Company Baldor
Part Number bsm80n_175ba
AMB. 25
Ambient Temperature 25 C
Base Indicator Bracket Mounted
Bearing Grease Type POLYREX EM
CLASS F
Constant stall current 2.14 A
CUR CONT STALL/A RMS 2,08
Dimensional Drawing Numbers S2LYP117
Duty Rating CONT
Frame D100D
Frame Material Exposed Laminations
Frame Suffix D
Insulation Class F
IP Rating IP54
MAX MECH SPEED No
Max Speed 7,000 rpm
Max Speed Rpm 7000
Motor Lead Exit Front End
Motor Lead Quantity/Wire Size 3 @ 18 AWG
Multiplier Symbol E4
Nameplate Amps 2,08
Nameplate Output 0.58KW
Nameplate Speed 4000
Nameplate Voltage 300
Number of Poles 4
PEACK CUR/A RMS 7,47
Peak Current 7.5 A
Peak Torque 6.6 N-m
POWER 0.58KW
RATED BUS VOLTS 300
RATED SPEED/RPM 4000
Rated Torque 1.65 N-m
RoHS Status RoHS Compliant
Rotor Inertia (Servo) 0,00093
Shaft Diameter 0.748 in
Ship Weight 12 LB
SPEC. S2P117W039G1
Speed 4,000 rpm
Thermal Resistance No
Thermal Time Constant No
TORQ CONT STALL 1.65 NM
UPC 781568441442
