BSM80C-275RA
BSM80C-275RA
BSM80C-275RA TSTAT RESOLVER
Company Baldor
Part Number bsm80c_275ra
Agency Approvals CE CSA TUV UR
AMB. 25
Ambient Temperature 25 C
AMPS No
Base Indicator Bracket Mounted
Bearing Grease Type POLYREX EM
BRG/DE No
BRG/ODE No
CLASS F
Constant stall current 3.24 A
CUR CONT STALL/A RMS 3,24
Dimensional Drawing Numbers S2LYP343
DUTY No
Duty Rating CONT
ENCL No
Frame No
Frame Material Exposed Laminations
Frame Suffix D
HP No
INSUL No
Insulation Class F
IP Rating No
Max Speed 7,000 rpm
Max Speed Rpm 7000
Motor Lead Exit Front End
Motor Lead Quantity/Wire Size 3 @ 18 AWG
Multiplier Symbol E4
Nameplate Amps 3,24
Nameplate Output 0.92KW
Nameplate Speed 4000
Nameplate Voltage 300
Number of Poles 4
PEACK CUR/A RMS 8,25
Peak Current 8.3 A
Peak Torque 7.2 N-m
POWER 0.92KW
RATED BUS VOLTS 300
RATED SPEED/RPM 4000
Rated Torque 2.40 N-m
RoHS Status No
Rotor Inertia (Servo) 0,00331
RPM No
SER.F. No
Service Factor No
Shaft Diameter 0.748 in
Ship Weight 10 LB
SPEC. S2P343W048
Speed 4,000 rpm
TORQ CONT STALL 2.4 NM
UPC 781568500057
VOLTS No
