BSM80C-250AF
BSM80C-250AF
BSM80C-250AF TSTAT, ENCODER
Company Baldor
Part Number bsm80c_250af
Agency Approvals CE CSA TUV UR
AMB. 25
Ambient Temperature 25 C
AMPS No
Base Indicator Bracket Mounted
Bearing Grease Type POLYREX EM
BRG/DE No
BRG/ODE No
CLASS F
Constant stall current 5.20 A
CUR CONT STALL/A RMS 5,21
Dimensional Drawing Numbers S2LYP196
DUTY No
Duty Rating CONT
ENCL No
Frame No
Frame Material Exposed Laminations
Frame Suffix D
HP No
INSUL No
Insulation Class F
IP Rating IP54
Max Speed 7,000 rpm
Max Speed Rpm 7000
Motor Lead Exit Front End
Motor Lead Quantity/Wire Size 3 @ 18 AWG
Multiplier Symbol E4
Nameplate Amps 5,21
Nameplate Output 1.02KW
Nameplate Speed 6000
Nameplate Voltage 300
Number of Poles 4
PEACK CUR/A RMS 13,3
Peak Current 13.3 A
Peak Torque 7.2 N-m
POWER 1.02KW
RATED BUS VOLTS 300
RATED SPEED/RPM 6000
Rated Torque 2.40 N-m
RoHS Status RoHS Compliant
Rotor Inertia (Servo) 0,00331
RPM No
SER.F. No
Service Factor No
Shaft Diameter 0.748 in
Ship Weight 11 LB
SPEC. S2P196W054
Speed 6,000 rpm
TORQ CONT STALL 2.4 NM
UPC 781568400012
VOLTS No
