BSM80B-275AF
BSM80B-275AF
BSM80B-275AF T'STAT, ENCODER
Company Baldor
Part Number bsm80b_275af
AMB. 25
Ambient Temperature 25 C
Base Indicator Bracket Mounted
Bearing Grease Type POLYREX EM
CLASS F
CUR CONT STALL/A RMS 3,38
Dimensional Drawing Numbers S2LYP141
Duty Rating CONT
Frame D100D
Frame Material Exposed Laminations
Frame Suffix D
Insulation Class F
IP Rating IP54
Max Speed 7,000 rpm
Max Speed Rpm 7000
Motor Lead Exit Front End
Motor Lead Quantity/Wire Size 3 @ 18 AWG
Multiplier Symbol E4
Nameplate Amps 3,38
Nameplate Output 0.89KW
Nameplate Speed 4000
Nameplate Voltage 300
Number of Poles 4
PEACK CUR/A RMS 10,1
Peak Current 10.1 A
Peak Torque 7.7 N-m
POWER 0.89KW
RATED BUS VOLTS 300
RATED SPEED/RPM 4000
Rated Torque 2.20 N-m
RoHS Status RoHS Compliant
Rotor Inertia (Servo) 0,005
Shaft Diameter 0.748 in
Ship Weight 16 LB
SPEC. S2P141W016
Speed 4,000 rpm
TORQ CONT STALL 2.2 NM
UPC 781568793701
