BSM80B-175AA
BSM80B-175AA
BSM80B-175AA
Company Baldor
Part Number bsm80b_175aa
AMB. 25
Ambient Temperature 25 C
Base Indicator Bracket Mounted
Bearing Grease Type POLYREX EM
CLASS F
CUR CONT STALL/A RMS 2,59
Dimensional Drawing Numbers S2LYP100
Duty Rating CONT
Frame D100D
Frame Material Exposed Laminations
Frame Suffix D
Insulation Class F
IP Rating IP54
Max Speed 7,000 rpm
Max Speed Rpm 7000
Motor Lead Exit Front End
Motor Lead Quantity/Wire Size 3 @ 18 AWG
Multiplier Symbol E4
Nameplate Amps 2,59
Nameplate Output 0.57KW
Nameplate Speed 4000
Nameplate Voltage 300
Number of Poles 4
PEACK CUR/A RMS 7,71
Peak Current 7.7 A
Peak Torque 5.7 N-m
POWER 0.57KW
RATED BUS VOLTS 300
RATED SPEED/RPM 4000
Rated Torque 1.63 N-m
RoHS Status RoHS Compliant
Rotor Inertia (Servo) 0,0031
Shaft Diameter 0.748 in
Ship Weight 12.45 LB
SPEC. S2P100W014G1
Speed 4,000 rpm
TORQ CONT STALL 1.63 NM
UPC 781568284834
