BSM63N-375RF
BSM63N-375RF
BSM63N-375RF TSTAT ENCODER
Company Baldor
Part Number bsm63n_375rf
AMB. 25
Ambient Temperature 25 C
Base Indicator Bracket Mounted
Bearing Grease Type POLYREX EM
CLASS F
Constant stall current 2.82 A
CUR CONT STALL/A RMS 2,82
Dimensional Drawing Numbers S1LYP203
Duty Rating CONT
Frame D75D
Frame Material Exposed Laminations
Frame Suffix D
Insulation Class F
IP Rating No
MAX MECH SPEED 10000
Max Speed 1,000 rpm
Max Speed Rpm No
Motor Lead Exit Front End
Motor Lead Quantity/Wire Size 3 @ 18 AWG
Multiplier Symbol E4
Nameplate Amps 2,82
Nameplate Output 0.64KW
Nameplate Speed 4000
Nameplate Voltage 300
Number of Poles 4
PEACK CUR/A RMS 10,2
Peak Current 10.2 A
Peak Torque 8.4 N-m
POWER 0.64KW
RATED BUS VOLTS 300
RATED SPEED/RPM 4000
Rated Torque 2.09 N-m
RoHS Status RoHS Compliant
Rotor Inertia (Servo) 0,0005
Shaft Diameter 0.433 in
Ship Weight 9.15 LB
SPEC. S1P203W035
Speed 4,000 rpm
Thermal Resistance No
Thermal Time Constant No
TORQ CONT STALL 2.09 NM
UPC 781568500453
