BSM63N-375RA
BSM63N-375RA
BSM63N-375RA TSTAT RESOLVER
Company Baldor
Part Number bsm63n_375ra
AMB. 25
Ambient Temperature 25 C
Base Indicator Bracket Mounted
Bearing Grease Type POLYREX EM
CLASS F
Constant stall current 2.82 A
CUR CONT STALL/A RMS 2,82
Dimensional Drawing Numbers S1LYP174
Duty Rating CONT
Frame D75D
Frame Material Exposed Laminations
Frame Suffix D
Insulation Class F
IP Rating No
MAX MECH SPEED 10000
Max Speed 1,000 rpm
Max Speed Rpm No
Motor Lead Exit Front End
Motor Lead Quantity/Wire Size 3 @ 18 AWG
Multiplier Symbol E4
Nameplate Amps 2,82
Nameplate Output 0.64KW
Nameplate Speed 4000
Nameplate Voltage 300
Number of Poles 4
PEACK CUR/A RMS 10,2
Peak Current 10.2 A
Peak Torque 8.4 N-m
POWER 0.64KW
RATED BUS VOLTS 300
RATED SPEED/RPM 4000
Rated Torque 2.09 N-m
RoHS Status No
Rotor Inertia (Servo) 0,0005
Shaft Diameter 0.433 in
Ship Weight 9 LB
SPEC. S1P174W035
Speed 4,000 rpm
Thermal Resistance No
Thermal Time Constant No
TORQ CONT STALL 2.09 NM
UPC 781568500446
