BSM63N-275RF
BSM63N-275RF
BSM63N-275RF TSTAT ENCODER
Company Baldor
Part Number bsm63n_275rf
AMB. 25
Ambient Temperature 25 C
Base Indicator Bracket Mounted
Bearing Grease Type POLYREX EM
CLASS F
Constant stall current 1.94 A
CUR CONT STALL/A RMS 1,94
Dimensional Drawing Numbers S1LYP203
Duty Rating CONT
Frame D75D
Frame Material Exposed Laminations
Frame Suffix D
Insulation Class F
IP Rating No
MAX MECH SPEED 10000
Max Speed 1,000 rpm
Max Speed Rpm No
Motor Lead Exit Front End
Motor Lead Quantity/Wire Size 3 @ 18 AWG
Multiplier Symbol E4
Nameplate Amps 1,94
Nameplate Output 0.53KW
Nameplate Speed 4000
Nameplate Voltage 300
Number of Poles 4
PEACK CUR/A RMS 6,96
Peak Current 7.0 A
Peak Torque 5.9 N-m
POWER 0.53KW
RATED BUS VOLTS 300
RATED SPEED/RPM 4000
Rated Torque 1.47 N-m
RoHS Status RoHS Compliant
Rotor Inertia (Servo) 0,00034
Shaft Diameter 0.433 in
Ship Weight 8 LB
SPEC. S1P203W034
Speed 4,000 rpm
Thermal Resistance No
Thermal Time Constant No
TORQ CONT STALL 1.47 NM
UPC 781568481318
