BSM63N-275RA
BSM63N-275RA
BSM63N-275RA TSTAT RESOLVER
Company Baldor
Part Number bsm63n_275ra
AMB. 25
Ambient Temperature 25 C
Base Indicator Bracket Mounted
Bearing Grease Type POLYREX EM
CLASS F
Constant stall current 1.94 A
CUR CONT STALL/A RMS 1,94
Dimensional Drawing Numbers S1LYP174
Duty Rating CONT
Frame D75D
Frame Material Exposed Laminations
Frame Suffix D
Insulation Class F
IP Rating No
MAX MECH SPEED 10000
Max Speed 1,000 rpm
Max Speed Rpm No
Motor Lead Exit Front End
Motor Lead Quantity/Wire Size 3 @ 18 AWG
Multiplier Symbol E4
Nameplate Amps 1,94
Nameplate Output 0.53KW
Nameplate Speed 4000
Nameplate Voltage 300
Number of Poles 4
PEACK CUR/A RMS 6,96
Peak Current 7.0 A
Peak Torque 5.9 N-m
POWER 0.53KW
RATED BUS VOLTS 300
RATED SPEED/RPM 4000
Rated Torque 1.47 N-m
RoHS Status RoHS Compliant
Rotor Inertia (Servo) 0,00034
Shaft Diameter 0.433 in
Ship Weight 7.7 LB
SPEC. S1P174W034
Speed 4,000 rpm
Thermal Resistance No
Thermal Time Constant No
TORQ CONT STALL 1.47 NM
UPC 781568500040
