BSM63N-233AA
BSM63N-233AA
BSM63N-233AA (NEO) TSTAT, RESOLVE
Company Baldor
Part Number bsm63n_233aa
AMB. 25
Ambient Temperature 25 C
Base Indicator No Mounting
Bearing Grease Type POLYREX EM
CLASS F
Constant stall current 3.93 A
CUR CONT STALL/A RMS 3,93
Dimensional Drawing Numbers S1LYP100
Duty Rating CONT
Frame No
Frame Material Exposed Laminations
Frame Suffix D
Insulation Class F
IP Rating No
MAX MECH SPEED 10000
Max Speed 1,000 rpm
Max Speed Rpm No
Motor Lead Exit Front End
Motor Lead Quantity/Wire Size 3 @ 18 AWG
Multiplier Symbol E4
Nameplate Amps 3,93
Nameplate Output 0.69KW
Nameplate Speed 6000
Nameplate Voltage 200
Number of Poles 4
PEACK CUR/A RMS 14,2
Peak Current 14.2 A
Peak Torque 5.9 N-m
POWER 0.69KW
RATED BUS VOLTS 200
RATED SPEED/RPM 6000
Rated Torque 1.47 N-m
RoHS Status RoHS Compliant
Rotor Inertia (Servo) 0,00034
Shaft Diameter 0.433 in
Ship Weight 7 LB
SPEC. S1P100W038G1
Speed 6,000 rpm
Thermal Resistance No
Thermal Time Constant No
TORQ CONT STALL 1.47 NM
UPC 781568293393
