BSM50N-375AA
BSM50N-375AA
BSM50N-375AA (NEO) TSTAT, RESOLVER
Company Baldor
Part Number bsm50n_375aa
AMB. 25
Ambient Temperature 25 C
Base Indicator Bracket Mounted
Bearing Grease Type POLYREX EM
CLASS F
Constant stall current 2.38 A
CUR CONT STALL/A RMS 2,38
Dimensional Drawing Numbers S5LYP037
Duty Rating CONT
Frame No
Frame Material Exposed Laminations
Frame Suffix D
Insulation Class F
IP Rating No
MAX MECH SPEED 10000
Max Speed 1,000 rpm
Max Speed Rpm No
Motor Lead Exit Front End
Motor Lead Quantity/Wire Size 3 @ 18 AWG
Multiplier Symbol E4
Nameplate Amps 2,38
Nameplate Output 0.51KW
Nameplate Speed 4000
Nameplate Voltage 300
Number of Poles 4
PEACK CUR/A RMS 8
Peak Current 8.0 A
Peak Torque 5.4 N-m
POWER 0.51KW
RATED BUS VOLTS 300
RATED SPEED/RPM 4000
Rated Torque 1.36 N-m
RoHS Status RoHS Compliant
Rotor Inertia (Servo) 0,00016
Shaft Diameter 0.355 in
Ship Weight 4 LB
SPEC. S5P037W026
Speed 4,000 rpm
Thermal Resistance No
Thermal Time Constant No
TORQ CONT STALL 1.36 NM
UPC 781568293348
