BSM50N-275AF
BSM50N-275AF
BSM50N-275AF TSTAT ENCODER
Company Baldor
Part Number bsm50n_275af
AMB. 25
Ambient Temperature 25 C
Base Indicator Bracket Mounted
Bearing Grease Type POLYREX EM
CLASS F
Constant stall current 1.42 A
CUR CONT STALL/A RMS 1,42
Dimensional Drawing Numbers S5LYP047
Duty Rating CONT
Frame D63D
Frame Material Exposed Laminations
Frame Suffix D
Insulation Class F
IP Rating No
MAX MECH SPEED 10000
Max Speed 1,000 rpm
Max Speed Rpm No
Motor Lead Exit Front End
Motor Lead Quantity/Wire Size 3 @ 18 AWG
Multiplier Symbol E4
Nameplate Amps 1,42
Nameplate Output 0.18KW
Nameplate Speed 2000
Nameplate Voltage 160
Number of Poles 4
PEACK CUR/A RMS 4,87
Peak Current 4.9 A
Peak Torque 3.7 N-m
POWER 0.18KW
RATED BUS VOLTS 160
RATED SPEED/RPM 2000
Rated Torque 0.91 N-m
RoHS Status RoHS Compliant
Rotor Inertia (Servo) 0,0011
Shaft Diameter 0.355 in
Ship Weight 5.75 LB
SPEC. S5P047W020G2
Speed 2,000 rpm
Thermal Resistance No
Thermal Time Constant No
TORQ CONT STALL 0.91 NM
UPC 781568414163
