BSM50N-233AA
BSM50N-233AA
BSM50N-233AA (NEO) TSTAT, RESOLVER
Company Baldor
Part Number bsm50n_233aa
AMB. 25
Ambient Temperature 25 C
Base Indicator Bracket Mounted
Bearing Grease Type POLYREX EM
CLASS F
Constant stall current 2.87 A
CUR CONT STALL/A RMS 2,87
Dimensional Drawing Numbers S5LYP037
Duty Rating CONT
Frame No
Frame Material Exposed Laminations
Frame Suffix D
Insulation Class F
IP Rating No
MAX MECH SPEED 10000
Max Speed 1,000 rpm
Max Speed Rpm No
Motor Lead Exit Front End
Motor Lead Quantity/Wire Size 3 @ 18 AWG
Multiplier Symbol E4
Nameplate Amps 2,87
Nameplate Output 0.36KW
Nameplate Speed 4000
Nameplate Voltage 160
Number of Poles 4
PEACK CUR/A RMS 9,91
Peak Current 9.9 A
Peak Torque 3.7 N-m
POWER 0.36KW
RATED BUS VOLTS 160
RATED SPEED/RPM 4000
Rated Torque 0.91 N-m
RoHS Status RoHS Compliant
Rotor Inertia (Servo) 0,00011
Shaft Diameter 0.355 in
Ship Weight 5.85 LB
SPEC. S5P037W024
Speed 4,000 rpm
Thermal Resistance No
Thermal Time Constant No
TORQ CONT STALL 0.91 NM
UPC 781568293317
