BSM50N-133AF
BSM50N-133AF
BSM50N-133AF TSTAT ENCODER
Company Baldor
Part Number bsm50n_133af
AMB. 25
Ambient Temperature 25 C
Base Indicator Bracket Mounted
Bearing Grease Type POLYREX EM
CLASS F
Constant stall current 1.49 A
CUR CONT STALL/A RMS 1,49
Dimensional Drawing Numbers S5LYP047
Duty Rating CONT
Frame D63D
Frame Material Exposed Laminations
Frame Suffix D
Insulation Class F
IP Rating No
MAX MECH SPEED 10000
Max Speed 1,000 rpm
Max Speed Rpm No
Motor Lead Exit Front End
Motor Lead Quantity/Wire Size 3 @ 18 AWG
Multiplier Symbol E4
Nameplate Amps 1,49
Nameplate Output 0.19KW
Nameplate Speed 4000
Nameplate Voltage 160
Number of Poles 4
PEACK CUR/A RMS 5,07
Peak Current 5.1 A
Peak Torque 1.8 N-m
POWER 0.19KW
RATED BUS VOLTS 160
RATED SPEED/RPM 4000
Rated Torque 0.45 N-m
RoHS Status RoHS Compliant
Rotor Inertia (Servo) 0,00006
Shaft Diameter 0.355 in
Ship Weight 4 LB
SPEC. S5P047W019G3
Speed 4,000 rpm
Thermal Resistance 3C/WATT
Thermal Time Constant 700 min
TORQ CONT STALL 0.45 NM
UPC 781568793763
