BSM33C-4177MHQ
BSM33C-4177MHQ
32B TENV HOR 56C 1 HALL (1.5 HP)
Company Baldor
Part Number bsm33c_4177mhq
Agency Approvals CSA
AMB. 40
Ambient Temperature 40 C
AMPS 4
Base Indicator Rigid
Bearing Grease Type POLYREX EM
BRG/DE 6205
BRG/ODE 6203
CLASS No
Constant stall current 6.47 A
CUR CONT STALL/A RMS No
Dimensional Drawing Numbers 33LY3131
DUTY CONT
Duty Rating CONT
ENCL TENV
Frame 56C
Frame Material Steel
Frame Suffix C
HP 1,5
INSUL F
Insulation Class F
IP Rating No
Max Speed 7,000 rpm
Max Speed Rpm No
Motor Lead Exit Front End
Motor Lead Quantity/Wire Size 3 @ 14 AWG
Multiplier Symbol E4
Nameplate Amps 4
Nameplate Output 1,5
Nameplate Speed 1800
Nameplate Voltage 320
Number of Poles 8
PEACK CUR/A RMS No
Peak Current 13.9 A
Peak Torque 11.4 N-m
POWER No
RATED BUS VOLTS No
RATED SPEED/RPM No
Rated Torque 3.80 N-m
RoHS Status No
Rotor Inertia (Servo) 0,01033
RPM 1800
SER.F. 1
Service Factor 1
Shaft Diameter 0.625 in
Ship Weight 25 LB
SPEC. 33-3131W938
Speed 3,600 rpm
TORQ CONT STALL No
UPC 781568435113
VOLTS 320
