BSM25C-1177MHC
BSM25C-1177MHC
MTR 320VDC 1800 RPM BRUSHLESS .25 HP
Company Baldor
Part Number bsm25c_1177mhc
Agency Approvals CCSA US CE CSA CSA EEV TUV UL UR
AMB. 40
Ambient Temperature 40 C
AMPS 0,5
Base Indicator No
Bearing Grease Type POLYREX EM
BRG/DE No
BRG/ODE No
CLASS No
Constant stall current 1.50 A
CUR CONT STALL/A RMS No
Dimensional Drawing Numbers 25P002B002
DUTY CONT
Duty Rating CONT
ENCL No
Frame No
Frame Material No
Frame Suffix No
HP 0,25
INSUL F
Insulation Class F
IP Rating No
Max Speed 7,000 rpm
Max Speed Rpm No
Motor Lead Exit No
Motor Lead Quantity/Wire Size 3 @ 18 AWG
Multiplier Symbol E4
Nameplate Amps 0,5
Nameplate Output 0,25
Nameplate Speed 1800
Nameplate Voltage 320
Number of Poles 4
PEACK CUR/A RMS No
Peak Current 8.6 A
Peak Torque 3.6 N-m
POWER No
RATED BUS VOLTS No
RATED SPEED/RPM No
Rated Torque 1.20 N-m
RoHS Status No
Rotor Inertia (Servo) No
RPM 1800
SER.F. 1
Service Factor 1
Shaft Diameter No
Ship Weight 13 LB
SPEC. 25P002B002
Speed 4,000 rpm
TORQ CONT STALL No
UPC 781568435236
VOLTS 320
