BSM100N-4250AF
BSM100N-4250AF
BSM100N-4250AF TSTAT ENCODER
Company Baldor
Part Number bsm100n_4250af
AMB. 25
Ambient Temperature 25 C
Base Indicator Bracket Mounted
Bearing Grease Type POLYREX EM
CLASS F
Constant stall current 16.80 A
CUR CONT STALL/A RMS 16,9
Dimensional Drawing Numbers S4LYP064
Duty Rating CONT
Frame D165D
Frame Material Exposed Laminations
Frame Suffix D
Insulation Class F
IP Rating No
MAX MECH SPEED No
Max Speed 4,000 rpm
Max Speed Rpm 4000
Motor Lead Exit Front End
Motor Lead Quantity/Wire Size 3 @ 10 AWG
Multiplier Symbol E4
Nameplate Amps 16,9
Nameplate Output 4.04KW
Nameplate Speed 1200
Nameplate Voltage 300
Number of Poles 8
PEACK CUR/A RMS 60,7
Peak Current 60.7 A
Peak Torque 160.0 N-m
POWER 4.04KW
RATED BUS VOLTS 300
RATED SPEED/RPM 1200
Rated Torque 40 N-m
RoHS Status RoHS Compliant
Rotor Inertia (Servo) 0,0349
Shaft Diameter 1.103 in
Ship Weight 84 LB
SPEC. S4P064W062G2
Speed 1,200 rpm
Thermal Resistance No
Thermal Time Constant No
TORQ CONT STALL 40 NM
UPC 781568535486
