BSM100N-4150AF
BSM100N-4150AF
BSM100N-4150AF TSTAT ENCODER
Company Baldor
Part Number bsm100n_4150af
AMB. 25
Ambient Temperature 25 C
Base Indicator Bracket Mounted
Bearing Grease Type POLYREX EM
CLASS F
Constant stall current 26.90 A
CUR CONT STALL/A RMS 27
Dimensional Drawing Numbers S4LYP064
Duty Rating CONT
Frame D165D
Frame Material Exposed Laminations
Frame Suffix D
Insulation Class F
IP Rating No
MAX MECH SPEED No
Max Speed 4,000 rpm
Max Speed Rpm 4000
Motor Lead Exit Front End
Motor Lead Quantity/Wire Size 3 @ 10 AWG
Multiplier Symbol E4
Nameplate Amps 27
Nameplate Output 4.58KW
Nameplate Speed 2000
Nameplate Voltage 300
Number of Poles 8
PEACK CUR/A RMS 97,2
Peak Current 97.2 A
Peak Torque 160.0 N-m
POWER 4.58KW
RATED BUS VOLTS 300
RATED SPEED/RPM 2000
Rated Torque 40 N-m
RoHS Status RoHS Compliant
Rotor Inertia (Servo) 0,0349
Shaft Diameter 1.103 in
Ship Weight 83 LB
SPEC. S4P064W051G2
Speed 2,000 rpm
Thermal Resistance No
Thermal Time Constant No
TORQ CONT STALL 40 NM
UPC 781568535479
