BSM100N-3250AA
BSM100N-3250AA
BSM100N-3250AA (NEO) TSTAT, RESOLVE
Company Baldor
Part Number bsm100n_3250aa
AMB. 25
Ambient Temperature 25 C
Base Indicator Bracket Mounted
Bearing Grease Type POLYREX EM
CLASS F
Constant stall current 14.70 A
CUR CONT STALL/A RMS 14,8
Dimensional Drawing Numbers S4LYP100
Duty Rating CONT
Frame D165D
Frame Material Exposed Laminations
Frame Suffix D
Insulation Class F
IP Rating No
MAX MECH SPEED No
Max Speed 4,000 rpm
Max Speed Rpm 4000
Motor Lead Exit Front End
Motor Lead Quantity/Wire Size 3 @ 10 AWG
Multiplier Symbol E4
Nameplate Amps 14,8
Nameplate Output 2.63KW
Nameplate Speed 1200
Nameplate Voltage 300
Number of Poles 8
PEACK CUR/A RMS 53,1
Peak Current 53.1 A
Peak Torque 136.0 N-m
POWER 2.63KW
RATED BUS VOLTS 300
RATED SPEED/RPM 1200
Rated Torque 34 N-m
RoHS Status RoHS Compliant
Rotor Inertia (Servo) 0,0273
Shaft Diameter 1.103 in
Ship Weight 62 LB
SPEC. S4P100W060G1
Speed 1,200 rpm
Thermal Resistance No
Thermal Time Constant No
TORQ CONT STALL 34 NM
UPC 781568293270
