BSM100N-2250AA
BSM100N-2250AA
BSM100N-2250AA (NEO) TSTAT, RESOLVE
Company Baldor
Part Number bsm100n_2250aa
AMB. 25
Ambient Temperature 25 C
Base Indicator Bracket Mounted
Bearing Grease Type POLYREX EM
CLASS F
Constant stall current 9.90 A
CUR CONT STALL/A RMS 10
Dimensional Drawing Numbers S4LYP100
Duty Rating CONT
Frame D165D
Frame Material Exposed Laminations
Frame Suffix D
Insulation Class F
IP Rating No
MAX MECH SPEED No
Max Speed 4,000 rpm
Max Speed Rpm 4000
Motor Lead Exit Front End
Motor Lead Quantity/Wire Size 3 @ 14 AWG
Multiplier Symbol E4
Nameplate Amps 10
Nameplate Output 2.54KW
Nameplate Speed 1200
Nameplate Voltage 300
Number of Poles 8
PEACK CUR/A RMS 35,9
Peak Current 35.9 A
Peak Torque 92.0 N-m
POWER 2.54KW
RATED BUS VOLTS 300
RATED SPEED/RPM 1200
Rated Torque 23 N-m
RoHS Status RoHS Compliant
Rotor Inertia (Servo) 0,0196
Shaft Diameter 1.103 in
Ship Weight 53.25 LB
SPEC. S4P100W057G1
Speed 1,200 rpm
Thermal Resistance No
Thermal Time Constant No
TORQ CONT STALL 23 NM
UPC 781568293256
