BSM100N-2150AF
BSM100N-2150AF
BSM100N-2150AF TSTAT ENCODER
Company Baldor
Part Number bsm100n_2150af
AMB. 25
Ambient Temperature 25 C
Base Indicator Bracket Mounted
Bearing Grease Type POLYREX EM
CLASS F
Constant stall current 15.50 A
CUR CONT STALL/A RMS 15,5
Dimensional Drawing Numbers S4LYP064
Duty Rating CONT
Frame D165D
Frame Material Exposed Laminations
Frame Suffix D
Insulation Class F
IP Rating No
MAX MECH SPEED No
Max Speed 4,000 rpm
Max Speed Rpm 4000
Motor Lead Exit Front End
Motor Lead Quantity/Wire Size 3 @ 12 AWG
Multiplier Symbol E4
Nameplate Amps 15,5
Nameplate Output 3.57KW
Nameplate Speed 2000
Nameplate Voltage 300
Number of Poles 8
PEACK CUR/A RMS 55,8
Peak Current 55.8 A
Peak Torque 92.0 N-m
POWER 3.57KW
RATED BUS VOLTS 300
RATED SPEED/RPM 2000
Rated Torque 23 N-m
RoHS Status RoHS Compliant
Rotor Inertia (Servo) 0,0196
Shaft Diameter 1.103 in
Ship Weight 52.35 LB
SPEC. S4P064W056G1
Speed 2,000 rpm
Thermal Resistance No
Thermal Time Constant No
TORQ CONT STALL 23 NM
UPC 781568406038
